AutoCAD Forum
2014 Command Window Autohide
5 REPLIES 5
bakerdb
1618 Views, 5 Replies
I am not sure what I did, but I have had my Command Window set to Auothide and had the bar set at the bottom of my screen above the Applications Bar, but for some reason today it opened up with 70% transparency and will not Autohide.  There seems to be no option to Autohide it.
David B. Baker
CAD Supervisor
Munters Corporation - Aerotech Ventilation Systems
4215 Legion Drive - Mason, MI 48854 USA
800-227-2376 or 517-676-7070 ext 139
www.munters.com
david.baker@munters.com
5 REPLIES 5
pendean
in reply to: bakerdb
Do you have LOCKUI variable turned on by chance? Explained in HELP.
bakerdb
in reply to: pendean
Dean,
Thank you for the answer, I had gone back into AutoCAD and looked and my locks and I had Floating Windows locked, so I unlocked them and then was able to stretch the Command Window down to just the bar and then I relocked it and everthing is back to normal.
Thanks again.
David B. Baker
CAD Supervisor
www.munters.com
randy.valimont
I just loaded C3D 2014.  It's working great and I'm learning and liking the new add-ons.  But am having trouble with my Properties/Autohide going from docked to filling the entire screen.  It won't stay the size I want it.  When I hit Autohide to keep it as I've set it - it doesn't.  It goes across my entire screen.  The same with my Layer Properties Manager. Toolspace sidebar menu works fine.  Any suggestions.
t/y  Randy V.
pendean
in reply to: randy.valimont
Reply above yours posted how they fixed it: did you try that?
Herman
My Command Window has disappeared.
control 9 brings up text near the "?" at the top right hand corner.
See attached
”Boost
