AutoCAD 2013/2014/2015
hypersonic
Message 1 of 8 (271 Views)
2 viewports that keep everything in line and to the same zoom factor?
271 Views, 7 Replies
07-22-2012 12:55 PM
Is it possible to make 2 viewports that keep everything in line and to the same zoom factor?
I would like to be able to create a "front view" that always stays in line with the top view, just like orthographic views would be.....
Thanks!
grimline
Message 2 of 8 (264 Views)
Re: 2 viewports that keep everything in line and to the same zoom factor?
07-22-2012 04:15 PM in reply to: hypersonic
No, there is no way to keep 2 viewports in line besides manually.
But, there is a command called "UCSFOLLOW".
Autodesk AutoCAD Map 3D 2015
Windows 7 Professional
Service Pack 1
Intel(R) Core(TM) i5-4430 CPU @ 3.00 GHz
8.00 GB RAM
*Expert Elite*
drjohn
Message 3 of 8 (243 Views)
07-23-2012 08:31 AM in reply to: hypersonic
Actually, there is a way. Very simple.
Assumption: MVIEWS and PS
Set the scale for each mview the same (match object paintbrush will work)
Select the mview you want to move (the mview frame).  Then you can select a line that is appropriate that is WITHIN the mview and snap it perp or whatever to a line in the other mview.
HTH
DJ
*Expert Elite*
dbroad
Message 4 of 8 (235 Views)
07-23-2012 10:03 AM in reply to: hypersonic
Although not technically what you are asking for, if using 3d solids, look at the viewbase ommand.
You can also lock paper space viewports and can align them with mvsetup.
Distinguished Contributor
itr0045
Message 5 of 8 (210 Views)
07-24-2012 01:08 PM in reply to: hypersonic
Under the Express menu there is a command called Synchronize Vieports, the typed command is "vpsync".  This may be what you are looking for.
hypersonic
Message 6 of 8 (191 Views)
07-25-2012 06:55 AM in reply to: itr0045
Hmmm trying the vpsync command and it says "Command not allowed unless TILEMODE is set to 0"
Which if I am understanding this right is the paper space viewports mode.
So I swithc tilemode to 0 and try again and then it says " There are no active Model space viewports"
Not sure what I am missing here ??
Thank you for all the input!
*Expert Elite*
dbroad
Message 7 of 8 (183 Views)
07-25-2012 11:24 AM in reply to: hypersonic
In your first message, you should have indicated that you were interested in model tab viewports.  There are no commands to keep these in sync.
You should learn to use paper space viewports, especially if you want the views plotted next to one another.  Only the current model tab viewport can be plotted at a time.
*Expert Elite*
drjohn
Message 8 of 8 (181 Views)
07-25-2012 11:44 AM in reply to: hypersonic
Now maybe try my solution (3rd post).
Select an mview (what you are calling a viewport) and everything associated with it (text or dims or whatever) and move them perp to or whatever to an mview that you want to align to selecting objects or lines INSIDE the mview.
Quite simple, very basic and it works.
HTH
DJ
Need installation help?
