AutoCAD 2013/2014/2015
Distinguished Contributor
diesellam
Message 1 of 5 (429 Views)
0,0,0 point
429 Views, 4 Replies
12-06-2012 03:50 PM
I recently have this problem in certain 2d DWG files.
The 0,0,0 is different when I try to locate where it is.  It keeps giving different point in the file.
What's causing this problem?  Thanks in advance.
Active Contributor
kentw
Message 2 of 5 (419 Views)
Re: 0,0,0 point
12-06-2012 04:51 PM in reply to: diesellam
It is porbably becuase you have the dynamic input on and it is always doing relative.  try turning dynamic input off. F12 should be the hotkey to toggle it off and on.
_________________________________________________________________
KarelCAD Application Support Specialist
Alfred.NESWADBA
Message 3 of 5 (407 Views)
Re: 0,0,0 point
12-06-2012 11:22 PM in reply to: diesellam
How do you recognize/verify that the origin "is different"? ....different to what? To your current view or in relation to an object? What is the reference you use while verifying that?
Another option may be you have created a UCS with another origin.
- alfred -
Alfred NESWADBA
bvandamm
Message 4 of 5 (392 Views)
Re: 0,0,0 point
12-07-2012 08:40 AM in reply to: diesellam
Check your INSBASE system variable. Make sure that's set to 0,0,0 as well (gets changed when you wblock something out). Not sure if that's what's going on because I'm not sure if I understand your question correctly.
"The source of expertise is not in the memorization
of the minute details of a subject but in the thorough
understanding of the fundamental concepts on
which it is based." - Dan Appleman
diesellam
Message 5 of 5 (389 Views)
Re: 0,0,0 point
12-07-2012 08:50 AM in reply to: diesellam
I think the F12 does the trick, now the 0,0,0 is correct.
What I meant is when I draw a line, starting at 0,0,0, it doesn't snap to the intersection of the X,Y axis, but rather some randome point close to it.  It just happened in this file for some reason.
I want to make sure the structural grid is the same on every floor (relative to the 0,0,0)
Thanks all.
