I set up drawings with xref overlays set with a relative path.
I start working on my drawing, however, since many people are working on the project the xref change while I am editing my drawings. If this happens and I do not reload the xref while in the current editing secession and save and close my drawing (without reloading changed xrefs) then the next time I open the drawing the xref paths in my drawing becomes full path instead of the relative which I had originally set.
Are your xref files and the drawing files located on the same drive?
Are they located in the same folder?
Hi Shiraz,
I tried to reproduce this issue from scratch, but it doesn't seem to happen here on my system. Is this happening to all of your files, or only certain ones?
Have you checked for file corruption?
Are the files in a format other than the 2013 file format?
Do you have all service packs and hotfixes installed?
Are you using Sheet Set Manager?
If a lot of people are working on these drawings are you sure they are on a local drive?
Seems to me they are propably on a networked drive.
If some files are on your local drive and others on a network drive, relative path xrefs are not possible.
As long as they reside on the same drive, relative xrefs will work and should not change to full path by themselves.
Hi Shiraz,
This may be an unsupported configuration, since Autodesk products require a Microsoft network/environment to function properly.
You may want to determine what type of network environment you're introducing into the equation by using the Dropbox service.
