It has been a while that I don't use autocad. I was using 2007 version in 2009. I just got 2016 version and trying to adjust the new version. I have problem with one of the easiest comand 'Offset'. When I apply offset to a line,pline or an object, I can't use object snap with the new line,pline even though object snap is ON. What am I doing wrong?I am trying to figure out and getting crazy about it.
Thank you
Solved by Alfred.NESWADBA. Go to Solution.
Welcome to the Forums!
Command: OSNAP > Object Snap tab > Are any "object snap modes" checked?
Also verify "Object snap on" & "Object snap tracking" are checked.
Thank you ! It doesn't matter if they all checked or some of them checked. I tried "object snap on" & "object snap tracking" are checked also. Funny thing is I can use object snap for the main line but not for the copied with the offset command. A few minutes ago I realized that I can use object snap for the copied one when I zoom out. But when I zoom out it is hard to see which point I am picking.
welcome @Anonymous.autodesk.com!
Sorry that I can't follow the description, can you describe it step by step, what to do.
What I tried now, as you wrote you can't use object snap on an entity which was created by offset:
Can you reproduce my steps and you don't get the endpoint-snap.
And btw. you have already installed SP1 for AutoCAD?
- alfred -
