I have a folder called NHT which I'm told contains an add-on [lsp?] for 2d piping, steel etc. symbols. However, CUILOAD will not accept the folder itself. Am I expected to separalely load each and every file within that folder?
Solved by Volker_C. Go to Solution.
Solved by pendean. Go to Solution.
Solved by Patchy. Go to Solution.
I loaded the 6 lisp files, but when I run the NHT4 command, nothing happens. The command line shows "Command: NHT4
; error: quit / exit abort". I noticed there are more lisp files within the 13 folders. Should I load them as well?
why not asking the vendor of that software? He will hopefully provide you a setup which makes the loading of the files and config of AutoCAD in that order needed.
- alfred -
Hi!
Dean is correct, if those LISP files are that old chances are that many of them will need updating. The best bet would be to use load your blocks using DesignCenter or adding those blocks to a tool palette where you can easily insert them.
Back to Basics: Reusing Content with Ease (DesignCenter & Tool Palettes Revisited)
Hope this helps. Cheers,
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
