I downloaded AutoCAD 2014 ( windows x64 bit ) yesterday. It was installed successfully as shown by the installation wizard. When i used this installed AutoCAD 2014 for the very first time, this pop-up ( find the screenshot and screencast below ) occured. After that each time i open AutoCAD, this pop-up occurs. I just move on to my work in AutoCAD by clicking on 'continue' option.
What is this pop-up? Is it harmful? If yes, what i should do? If not, how i should avoid it?
In the pop-up, it is mentioned that the file AutoCAD 2014 is opening does not belong to AutoCAD Education Suite. I made this file in AutoCAD itself few months ago !
Solved by JDMather. Go to Solution.
Maybe this document was created by AutoCAD Educational version. If not use educational version please check this link.
TuncayBAKKAL
AutoCAD Eğitmeni ve Danışmanı
AutoCAD ve Fusion 360 Görsel Eğitim
Fusion 360 Kitabı Çıktı!
http://www.tuncaybakkal.com
Instagram: @tuncay_bakkal
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudos") ile ödüllendirin.
Assuming this is a student license - you can ignore this pop-up.
It is merely letting the user know that the original templates were not created with student license.
The CADWhisperer YouTube Channel
