I want to be able to print multiple drawings to PDF either Sheet Set Manager or the Publish command and have the files save individualy with only the tab name in the file name. Is there a way to do this just by manipulating setting in autocad or the pc3 file? It seems like this is a problem that could be with in the pc3 file. I have also notice when you include a period within the model file name of the tab name the generated name when printed does not include anything after then period. I wonder if it is also possible to remove everything in front of a certain character.
In the publish dialog box select Publish Options and set the type to single sheet file.
This will publish the sheets to single file PDFs
