- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have contour lines and borehole data from an area and I want to merge them. When I add the borehole data to my contour lines I can see that they end up on the 0 point on the x-axis even though they contain z-data. If i run a profile with GS Plan I get the borehole data with the correct depth but I do not get the topography.
How do I merge these data sets? I have tried to raise the borehole data manually so it is in the same z-level as the contour lines, does not help.
I then thought I could create a surface out of my contour lines with e.g. drape or create surface. I do not find the drape function (saw it on youtube) and I can not make the create surface function work.
Currently I am trying to work with layers, e.g. merge. Maybe change layer properties. But I do not know if that is the way to go.
Any tips?
Cheers
Dag Erlend
