Last two days I got a "FATAL ERROR: Unhandled e06d7363h Exception at fe638b9ch" every time I try to work with my project. Recently I have installed Revit 2014, may this cause the problem?
My computer parameters are:
- Processor / Type Core i7- 4790K
- Processor / Clock Speed 3.6 GHz
- Mainboard / Chipset Type Intel Z97 Express
- RAM / Total Installed Size 8 GB
- Graphics Controller NVIDIA GeForce GTX 750 Ti
- Video Memory / Installed Size 2 GB
- Operating System Microsoft Windows 8.1 64-bit
Thank you for your help.
Solved by matthew.d. Go to Solution.
Hi @almazmah,
Welcome to the community!
Sorry to hear about the issue. Have you tried resetting your user settings? Note: This will set things back to default and any customization will be lost. Also, try updating your graphics card driver.
Hello @almazmah
Are you speaking about AutoCAD ?
If YES, which version with which SP ?
If YES, please open your DWGs in RECOVER Mode ... to see if some errors are found and corrected !?
Re-Save your DWGs and test again ...
Regards, Patrice (I am not an Autodesk Advisor)
Patrice BRAUD
Hi Matt,
Thank you for your message. I have triedd to reset user settings - error still occurs.
I have updated driver until final version 353.62 for NVIDIA and already uninstalled Revit by supposing it was a reason for errors (before installation there weren't errors) - doesn't help.
Hope to hear from you soon.
Almaz.
Hi Patrice,
The version I'm using now is 2016. The SP is not known.
The screenshot is below.
Will see if there any errors happen.
Best regards,
Almaz.
Now I have another error:
FATAL ERROR: Unhandled e06d7363h Exception at fdfd8b9ch
Any more ideas would be appreciated.
Hi @almazmah,
Sorry to hear about the new issue, let's try a couple of things:
Hello Matt,
Thank you very much for your message.
Following your instructions I have reinstalled the latest versions of .NET framework ant DirectX. Till now the system works perfectly.
I wish you a great day,
With best regards,
Almaz.
