I just downloaded AutoCAD 2016 Educational version. But i couldn't start the program. When i try a message came all the time.
FATAL ERROR: unhandled access violation reading 0x0018 exception at 730f3733h
I use win7 Toshiba Satellite 64bit.
Could somebody help me please?
Solved by mahmutdemirbas. Go to Solution.
did the installation run without issues (and you did it as administrator and you had disabled antivirus and other defending software)?
What happens when you start AutoCAD by using a right-click on the desktop icon and use the option "start as administrator"?
Have you already passed the activation of AutoCAD or haven't you got the possibility yet?
Have you had a previous AutoCAD release on your system and you have chosen "migrate settings"?
What you can try:
Good luck, - alfred -
yes i did the installation without issues.
nothing changes when i use the option " start as adminastrator".
i haven't seen the activaton code part yet.
no i didn't have any previous release of AutoCAD before on my system.
i tried reseting the settings but it didn't work.
also i created a new user profile, gave it all permissions and set it as adminastrator then i tried to run AutoCAD but it didn't work too.
what else should i do?
does it start when you are not connected to any network (especially not to internet)?
That might be the primary source of the problem that this screen does not appear, you should be first asked if you want to run the software in a 30day trial or you want to activate the software. If that window does not pop up then it's just "you don't see it" .. means it could be outside the display areay or it's in the background of other windows (look to the taskbar how many windows are active, try <ALT><SPACE> to see if you get the window menu).
- alfred -
first i'd like to thank you for trying to help me.
i'm not connected to any networks but internet. i disconnected internet and tried again but it didn't work.
and i tried your other suggestion but it didn't work too. when i double click to AutoCAD shortcut the window of program opens. then this error message appears. should i try clean boot for windows? would it help me for solving this problem?
i followed the direction on this link and it has solved.
thank you for your feedback, good to know you got it solved.
For future readers: what graphic card and driver do you have that made it necessary to disable the hw-acceleration?
- alfred -
Hi mahmutdemirbas,
The solution you took is probably fine, but you lost the hardware acceleration. If you are using AMD video card, I suggest try this, so that you can use AutoCAD with hardware acceleration:
http://knowledge.autodesk.com/article/AutoCAD-2016-based-product-crashes-due-to-AMD-driver
The cause of the AutoCAD 2016 crash is in some AMD drivers. Please update video card driver (check toshiba website and see if there's recommended driver for your card on www.autodesk.com/hardware ). If there no updated driver for your hardware, please follow the second step to run AutoCAD in DirectX 9.
Hi Christopher Chen,
I also face similar problem with my laptop. I am using Zbook 15 iu G2 with Intel (R) HD Graphics 5500 graphic card. I did the same method (change to nohardware) and I manage to open autoCAD software but the performance is very slow. Do you have any suggestion ho to improve he performance.
Qusanssori
hii facing same problem iam unable to open the autocad 2016 showing same like you . what i have to do
@mahmutdemirbas wrote:first i'd like to thank you for trying to help me.
hii
iam getting same probkem i am unable to open the auto cad 2016 plz help me . to sove the proble
If it's the (exact) same problem then start at the link which is marked as solution.
- alfred -
There is a known issue with AMD driver - check whether you are using an AMD graphics card.
If you are using AMD card, the full fix would be going to amd.com to install the latest driver.
There is also a workaround for the problem in AutoCAD 2016 SP1, please install it too:
Disabling hardware acceleration should also work, but you will lose more performance and features with hardware acceleration off.
>> it is unable to work again after install ur link so what i can do
If you can give us more info's we might be able to help more efficient.
So let us know or show:
- alfred -
FATAL ERROR: unhandled access violation writing 0x40763000 exception at 6a54c3b9h
iam using windows 10 64bit
What is the Solition For the matter
@mahmutdemirbas wrote:I just downloaded AutoCAD 2016 Educational version. But i couldn't start the program. When i try a message came all the time.
I use win10 64bit.
@Alfred.NESWADBA wrote:Hi,
- screenshot with the exception message
- your system information (operating system, graphic card and -driver, memory)
- if you did a fresh install and AutoCAD never started or AutoCAD was always working well but stopped today with the exception
- do you have admin permissions and have you tried to start AutoCAD with right-click ==> option "start as administrator"
- did you try to start AutoCAD with disabled antivirus software
- have you tried to create a new Windows user and see if AutoCAD can start then
- alfred -
I know you weren't talking to me, but I'm having a similar issue.
I'm using AutoDesk Architecture 2016. It was fine yesterday when I left for lunch, I came back, woke my computer up (I put it to sleep before I left) and it had crashed/fatal excepted. It has crashed upon double clicking the icon ever since.
I have updated my AMD Firepro card. I've rebooted my computer. Still get the same fatal exception.
I did a screen cast (I appologize, I have 2 screens running and so it isn't the best but I think it has all the info you asked for lol).
http://autode.sk/1K1rn73
Thanks in Advance,Jennie
Sleeping mode is sometimes critical, especially if not every single piece of hardware has perfect drivers (also for the usb-sticks, btw. had you a harddisk or usb-stick plugged in?)
Try first to set your AutoCAD to default as described >>>here<<< or login with a new Windows user account and see if the same happens.
BTW: when exactly does your AutoCAD crash? Sometimes during work or with a specific drawing or when you start AutoCAD or ...?
- alfred -
