Ok so when I work, I use the NEAREST command within object snap a lot, but I prefer that it is not selected all the time when object snap is on.
So when I am using a command already like drawing a polyline or moving the endpoint of a line - within that command i use the alias NEAR.
Does anyone know if I can change the command for this alias command within a command? I'd just like to change it to N.
Solved by Patchy. Go to Solution.
Not within acad.pgp but it can be assigned to a F function key (e.g. F2, F3.... ) in the CUI
or it can be done with autolisp, and when running the command, use a ' mark.
Just so you know, the first three letters are enough as abbreviations for Osnap modes -- you can type just NEA and get that mode.
But you can also define a "command" for it that can be used transparently. Minimally tested:
(defun C:N () (command "_nearest"))
To use it in a drawing or editing command, you need to type the name with the asterisk prefix that @Patchy mentioned: 'N. One keystroke shorter than NEA....
And NEArest could be put in a Tool Palette button, and probably some other menu-pick options.
Thank you for explaining it in detail, I know it works like that but if I write it, it confuses people (English is my 2nd language)
Hi @Ringo311,
please take a look at this discussion - post no 14. Seems like it could work but should be a lot of work to rearrange all other snaps in order to make NEA working with only a <N>.
Regards
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Oh, come on ... as if you never forget anything
Well, at least I amused you
Thanks for the catch Patchy - link is inserted.
Regards
From my experience (and my settings) are F* keys the best option.
I have F1 for nearest and F2 for perpendicular.
Thanks all. I was able to assign it to F2 which seemed the easiest (and learned about the CUI). Ctrl + right click + "N" doesnt seem to save much effort from typing "NEA"
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
