In AutoCAD LT 2017 I have inadvertently positioned my command line or command window behind the Windows 10 lower toolbar. I can resize the AutoCAD LT window, but the command line or command window remains behind the Win 10 toolbar. This may have happened when moving AutoCAD LT window to an extended display.
I can find all sorts of information on where the command line can be located or docked, but nothing on getting it out from behind the Windows 10 toolbar.
Steve G. in MD
Solved by pendean. Go to Solution.
@SteveG_in_MD wrote:In AutoCAD LT 2017 I have inadvertently positioned my command line or command window behind the Windows 10 lower toolbar. I can resize the AutoCAD LT window, but the command line or command window remains behind the Win 10 toolbar. This may have happened when moving AutoCAD LT window to an extended display.
Steve G. in MD
Temporarily relocate your Windows taskbar, move your command line window, move your taskbar back.
You could always enable Auto-Hide for your windows task bar. Thereby having it disappear when not in use. Just a thought.
This set of instructions from the AUTODESK KNOWLEDGE NETWORK Article ID: kA230000000eEKD worked. It had me open the Customize User Interface (CUI) Editor and re-orient the COMMAND LINE. I didn't even know about the CUI Editor, so I really learned about a powerful feature.
It's possible the suggestions from others to temporarily move the Windows 10 Taskbar would have also worked, but I didn't try that.
Steve G. in MD
