Hello!
I installed trial version of AutoCAD 2017 on fresh widows 10 64 bit system, bet when I try to launch it, it instantly gives me error, included in attachment.
I have reinstalled it several times without changes.
What would you suggest?
Solved by ValdisPriednieks. Go to Solution.
Windows 10 display language must be English. There are problems with AutoCad 2017, AutoCad LT 2017 on regional Windows versions.
I have tried your solution but it still crashes when I try to start the program. Does the process change when I am using Windows 7? If so, please let me know if there is a solution for Windows 7?
Thank you very much!
