whenever you use the hatch command sends the message fatal mistake
and closes the program.
because that happens
already have the service pack 1 installed.
When you restart AutoCAD and load your drawing again, type in HPDLGMODE and set it to 1.
Now try the HATCH command again.
I TRIED THIS BUT STILL THE ERROR CONTINUE .PLS TELL SOME OTHER WAY TO RESOLVE THIS PROBLEM
caro amigo, estou com problema quando vou editar, ou deletar a hachura no desenho. Sempre que vou fazer isso, aparece e mensagem "fatal error". Como solucionar este problema?
Angelo
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
