Adjusting the font in properties toolbar
I have an issue regarding the sizing of the font within the properties palette to where I cannot read the contents. The few post responses that I have seen within the community recommend that I reduce the resolution of the font, there by making my high resolution screen a green screen. Yes, I am from the days of green screen monitors. For those of you that remember the magic {Load,8,1.*}
This seems like it should be a simple fix from Autodesk, by simpling pulling the font size from another designation instead of from the windows setting because the rest of the font sizes are fine. <screen caption below>
I appreciate the help as the only option has been to lower the font size down to where you need a microscope to read it, and adjusting the zoom on every other program up to compensate. Come on AutoDesk, fix the simple issues!
RobDraw
Are you using an older version on an ultra HD monitor?
Rob
TheCADnoob
try making your screen resolution in both directions below 2000
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gr...
CADnoob
john.vellek
Hi @Anonymous
You might check out this link to give input.
John Vellek
