AutoCAD 2010/2011/2012
New Member
pipeman449
Message 1 of 5 (1,247 Views)
zoom extents in paperspace
1247 Views, 4 Replies
08-22-2011 12:06 PM
when i use zoom extents command in ps layout flies way off into space and i cant get it back unless i undo. please help with limits or scale
*Expert Elite*
pendean
Message 2 of 5 (1,244 Views)
Re: zoom extents in paperspace
08-22-2011 12:09 PM in reply to: pipeman449
There is probably something, a block or a line or another entity, far-far away from your page: Zoom Extents means just that, find everything and zoom out to include them all.
Try ERASE command and go around the edges with a window.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
Julesagainn
Message 3 of 5 (1,201 Views)
08-25-2011 01:33 PM in reply to: pendean
I have had this problem pop up on occasion - make sure everything is unfrozen and unlocked, so you can find whatever object is hanging out there.
MKH-VB
Message 4 of 5 (1,179 Views)
08-29-2011 07:45 AM in reply to: Julesagainn
also check for a wipeout w/ frame turned off.  That has burned me in the past.
mkh
*Expert Elite*
Bob_Zurunkle
Message 5 of 5 (1,172 Views)
08-29-2011 09:12 AM in reply to: MKH-VB
OP is your VP locked?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
