AutoCAD 2010/2011/2012
Active Contributor
dbyrnes
Message 1 of 6 (390 Views)
Xrefs being automatically saved to wrong format
390 Views, 5 Replies
06-29-2010 12:13 PM
We’re working in AutoCAD 2010 but need to save as 2007 DWG. AutoCAD is set in Options to save to 2007 format, and all files - host and reference - are or should be in that format.
Something is triggering an automatic save of the xrefs. The xrefs are not being edited by me or anyone else, in-place or otherwise, but every so often I get a balloon message saying the xref has changed and I need to update it. So I update it, and when I check the file format, I find it’s been saved in 2010 DWG.
Other people on the project are also having this problem. Has anyone come across this, and is there a fix for it? This is painful - engineers on this project are using 2009 and keep coming to us and asking where the xrefs are.
This is AutoCAD 2010, "English Version 3" running in XP2 SP3.
JGerth
Message 2 of 6 (387 Views)
Re: Xrefs being automatically saved to wrong format
06-29-2010 12:30 PM in reply to: dbyrnes
Ouch -- that bites.  I have heard of that happening, but never experienced it.
Not at fix, but a possible bandaid would be to set the reference files to read-only on the server.  And scream to subscription support -- changing a reference file should NEVER EVER HAPPEN by the simple act of referencing it into an active drawing.  magic background save are not acceptable.
New Member
allan_nowak
Message 3 of 6 (102 Views)
02-21-2012 10:54 AM in reply to: dbyrnes
we are having the same issue using 2012 and would like to know if you found a solution?
thanks for the help
pendean
Message 4 of 6 (94 Views)
02-21-2012 11:28 AM in reply to: allan_nowak
Try the solution posted above as a workaround: but note that someone or an add-on is saving your Xrefs, plain AutoCAD on it's own does not (2012 or earlier). With the workaround above, the culprit will become very evident.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
allan_nowak
Message 5 of 6 (90 Views)
02-21-2012 11:41 AM in reply to: pendean
Does it matter that we are running MEP?
pendean
Message 6 of 6 (86 Views)
02-21-2012 12:03 PM in reply to: allan_nowak
it should not matter, but worth exploring that forum to see if it's something unique to that version.
