AutoCAD 2010/2011/2012
Active Contributor
nils126
Message 1 of 4 (462 Views)
Xref reloading problem
462 Views, 3 Replies
01-22-2013 03:29 PM
Hi, all. Every time I reload the xref, regenerating the drawing or plot my details, I need to wait a long while. I have a plan (dwg) and the details (dwg) where I xrefed the plan 6 times. Everythig is purged and audited. i thought this is a good way to work. Does anybody has some tips how to manage with xrefs. Thank you.
braudpat
Message 2 of 4 (391 Views)
Re: Xref reloading problem
01-31-2013 12:24 AM in reply to: nils126
Hello
Just an idea :
Open ALL yours XREFs
SCALELISTEDIT Command and erase/kill  ALL  Annotation Scales you can !
Resave your DWG ...
Reload your Main DWG, is it faster ?
Bye, Patrice
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
doben
Message 3 of 4 (369 Views)
02-02-2013 07:11 PM in reply to: nils126
You have the plan xref'd 6 times into the details dwg?
I'd suggest using just one instance of the xref, use vplayer contols and maybe annotative objects.
elaine3051
Message 4 of 4 (362 Views)
02-03-2013 09:00 AM in reply to: nils126
Run recover on all your xrefs and -Purge and delete all regapps. If a drawing, that is being used as an xref, has problems it brings those problems with it when you attach it.
