AutoCAD 2010/2011/2012
1,605 Kudos
Post 11 of 24
Re: Xref Problem
10-28-2011 06:03 AM in reply to: tcscad
One answer for many questions will not do...
Did you set FILEDIA to 1?
Nothing happens, but does AutoCAD act as though something is happening, perhaps off screen?
are you getting anything at the command line?
Have you restarted AutoCAD? Windows?
Did you recently explore dual screens, or an enlarged desktop scheme in Windows?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
0 Kudos
Post 12 of 24
Re: Xref Problem
11-01-2011 04:23 PM in reply to: Patchy
finally solved my problem
unfortunately the solution was to uninstall and reinstall Autocad 2012 (repair did not work)
xref browse window now opens when i pick the button to attach xref from xref panel
Active Member
0 Kudos
Post 13 of 24
Re: Xref Problem
11-07-2011 09:33 AM in reply to: tcscad
I run a computer lab with 25 machines with AutoCAD installed and I have no intention of reinstalling on all of them to fix this problem.
To clarify the problem:
No matter how I try to initalize the attach command, I get no dialog box to select the file I want to attach.
FILEDIA is set to 1
When I use the attach button in the XREF panel the command line prints CANCEL twice, then _XATTACH, then nothing happens.
601 Kudos
Post 14 of 24
Re: Xref Problem
11-07-2011 10:22 AM in reply to: crisby
All 25 stations do this? messed up from deployment ?
CUI and check the Macro of AttachXref to see if they all said: ^c^c_Xattach
Active Member
0 Kudos
Post 15 of 24
Re: Xref Problem
11-07-2011 10:33 AM in reply to: Patchy
The 25 that had Service Pack 1 installed all have the same attach command failure.
Other computers in the building without the service pack installed handle xref attaching just fine.
The macro for AttachXref is  ^C^C_xattach
601 Kudos
Post 16 of 24
Re: Xref Problem
11-07-2011 10:39 AM in reply to: crisby
Test by replace the .CUIX in the corrupted PC.
(Back up of the existing one)
That way you don't have to reinstall 25 of them.
Active Member
0 Kudos
Post 17 of 24
Re: Xref Problem
11-07-2011 11:04 AM in reply to: Patchy
Replacing the .cuix does not have any effect
601 Kudos
Post 18 of 24
Re: Xref Problem
11-07-2011 11:19 AM in reply to: crisby
Is this Plain autocad ?
If it's not, check :
CMDDIA =1
ATTDIA =1
Active Member
0 Kudos
Post 19 of 24
Re: Xref Problem
11-07-2011 11:24 AM in reply to: Patchy
AutoCAD 2012 Architecture
Both CMDDIA and ATTDIA are set to 1
Active Member
0 Kudos
Post 20 of 24
Re: Xref Problem
11-07-2011 03:30 PM in reply to: pendean
Oddly enough, if I turn FILEDIA to 0 I can manually type in the path to the file and it attaches just fine.
