AutoCAD 2010/2011/2012
Member
chris
Message 1 of 5 (1,659 Views)
Xref / Layer States Manager Question
1659 Views, 4 Replies
07-20-2011 11:51 AM
Ok here you go,
I have a Xref with multiple Layer States,
I xref'd it into a sheet with Floor plan Layer States,
nowi want to Xref it in again with the Ceiling Plan Layer Staes.
Just to be clear i want the same Xbase Xref'd in a sheet twice with 2 different layer states. how do i do this????
azrdgldr
Message 2 of 5 (1,640 Views)
Re: Xref / Layer States Manager Question
07-20-2011 02:28 PM in reply to: chris
The only way I could think of at the moment is to make a copy of your xref file and have one file with one layer states and the other with the other layer states.
Message 3 of 5 (1,624 Views)
07-20-2011 04:31 PM in reply to: chris
Can you get away with using viewport's layers?
  1. xref onto sheet
  2. create layout viewport1
  3. load layerstate1
  4. from within viewport1's model space, manipulate viewport layers to match model space layers (easy to do with creative sorting and mass matching), thaw/on/unlock all xref layers in model space, save as layerstate1a (or whatever)
  5. create layout viewport2
  6. load layerstate2
  7. repeat step 4, save as layerstate2a
New Member
dbraden
Message 4 of 5 (1,437 Views)
04-24-2012 10:19 AM in reply to: chris
Attach the base file > rename the attachment in the xref manager to something like XCLG > attach the same base file again > they should be listed individually > repeat as necessary
You must save the base file in which ever layer state you want it to be attached in prior to attaching each time. Make sure the option "Retain changes to Xref Layers" is checked under "Open and Save"
Distinguished Contributor
cvbt-thailand
Message 5 of 5 (1,237 Views)
Retain Changes to Xref Layers option clarification
11-28-2012 09:00 PM in reply to: dbraden
The "Retain Changes to Xref Layers" check box option is found in
TOOLS>OPTIONS>Open and Save>External References.
Geoffrey Wheeler
IV Pro 2011 64bit SP2; Win7 Ultimate SP1
ASUS MB Intel i5-3450 @ 3.10 GHz, 8GB RAM
ATI AMD Radeon HD 6600 Series, 1GB RAM
