AutoCAD 2010/2011/2012
Active Member
david.whalley
Message 1 of 5 (5,614 Views)
Xref layer linetypes and colours not updating
5614 Views, 4 Replies
01-07-2010 06:43 AM
When I change the linetypes and colours of a layer in a child drawing and then reload it in a parent drawing the changes are not reflected in the parent drawing.
VISRETAIN is set to 1 in the parent drawing as there are layers in the child drawing that need to be frozen off in the parent drawing.
Is there a command or variable that will allow the changed linetypes and colours to propagate to the parent drawing without loosing the layers frozen/thaw status, which results from setting VISRETAIN to 0.
thanks for any help.
Valued Contributor
steve-NEO
Message 2 of 5 (5,612 Views)
Re: Xref layer linetypes and colours not updating
01-07-2010 07:11 AM in reply to: david.whalley
Not sure if this helps but......
When ever the issue of colors/linetype/and LTscale, I've gone over the child drawing and verified it is what I want it to be (picking out what is wrong and verifing), this is time consuming and tedious but I've found that it works sometimes, the other thing I do to the parent drawing is purge out the old with -purge and regen.
Have a wonderful day,
Steve
*fieldguy
Message 3 of 5 (5,612 Views)
01-07-2010 07:35 AM in reply to: david.whalley
I noticed this yesterday. It is a PITA. The only answer I have is detach
and re-attach.
Valued Mentor
Randy_Culp
Message 4 of 5 (5,612 Views)
01-07-2010 02:01 PM in reply to: david.whalley
That's the way VISRETAIN is designed to work; layer settings are retained in the target drawing regardless of settings in the source file. Setting VISRETAIN to 0 means the source drawing layer settings will mimic the settings in the source file.
To reset to source file settings, UNLOAD the xref, set visretain to 0 (off) RELOAD the xref (layer settings will revert to source file) then reset VISRETAIN.
*fieldguy
Message 5 of 5 (5,611 Views)
01-07-2010 02:04 PM in reply to: david.whalley
Doh! Thanks.
Need installation help?
