AutoCAD Forum
Xline command no longer works in 2012
6 REPLIES 6
pete592
1948 Views, 6 Replies
I used to be able to create an xline simply by activating the command, and then picking two points through which I wanted the xline to pass through (for xlines that I do not want constrained to ortho).
Since the install of 2012, I activate the command, pick the first point, but no matter where I pick, the second point is ALWAYS *Invalid*.  It doesn't matter where I pick.  I can thrash and click all over the drawing and never find a valid second point for the xline to adhere to.
What changed in 2012's Xline command?   And what am I doing wrong?
Pete
6 REPLIES 6
braudpat
in reply to: pete592
Hello
Very strange !
I have just tested the _XLINE command on my 2012 & 2013 & 2014 french versions : no problem !
Maybe a stupid idea :
LIMITS
OFF
The Health, Happy New Year, Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
nestly2
Seems there's an issue with XLINE and Perp OSnap, but I don't believe that issue returns an "invalid" message.  Can you copy/paste your command line history here?
Command: XLINE
Specify a point or [Hor/Ver/Ang/Bisect/Offset]:
Specify through point:
rkmcswain
(a) Nothing AFAIK.
(2) Set OSMODE to 0 and try again.
pete592
in reply to: nestly2
Well, as of this particular moment, it looks like mine is doing what yours is doing.
There is no longer an *Invalid* message.
It's just perpetually asking for through points:
Command: XL
XLINE Specify a point or [Hor/Ver/Ang/Bisect/Offset]:
pete592
in reply to: rkmcswain
Ah, you're onto something.  I did try setting OSMODE to zero, and then manually entering the snap I want for each point of the Xline AND IT WORKED flawlessly.
So it appears that Osnap settings are at the heart of the problem.
At least I have a workaround now.  Thanks!
lag_art
I was having the same problem... until I realised the layer I was drawing on it was off. So, when I turned it on all the lines were there! Smiley Very Happy
”Boost
