AutoCAD 2010/2011/2012
Active Contributor
randomnewb
Message 1 of 7 (2,109 Views)
XLINE; BUGGGED?
2109 Views, 6 Replies
07-30-2010 08:22 AM
this in an issue ive noticed for a long time now across a few versions of ACAD, not sure whats causing it. When i try to draw an XLINE sometimes the command will get locked into either horizontal or vertical mode, without me choosing that option. seems to based on the OSNAP pickpoint i grab maybe.
attached are pics of the process.
i run XLINE, pick endpoint and bam, its locked into horizontal mode, very annoying if im trying to make a vertical and horizontal line based off the same point.
http://www.autocadeverything.com/help/showthread.php?5837-XLINE-BUGGGED
anwser is in there, thanks for the reply though Thayne, i do appreciate knowing Autodesk has my back :smileyhappy:
i almost always have ortho turned on
Appreciate the additional details in the link explaining that it could be Ortho or as found in your case the O-Snap "Perpendicular" is enabled.
Just trying to help.
thayne.wickam
Message 2 of 7 (2,049 Views)
Re: XLINE; BUGGGED?
08-19-2010 07:47 AM in reply to: randomnewb
I am not aware of a setting to force XLINE to be Horizontal by default.
I can only  reproduce your issue with specific settings but the Default never seems to be Horizontal on my systems. Your graphics are a little hard to follow so I put together a test for you to try.
Please review the following linked video.
http://screencast.com/t/OTlhNGRi
In the video the issue is repeatable by having Ortho turned on when selecting the Endpoint of a Rectangle.
Try my example and see what your results are compared to my video or just verify that your Ortho is off when doing this process and see if you get the results you are looking for.
Let me know if this helps.
Thayne Wickam
Support Specialist
Product Support
Active Contributor
randomnewb
Message 3 of 7 (2,046 Views)
Re: XLINE; BUGGGED?
08-19-2010 07:50 AM in reply to: thayne.wickam
thayne.wickam
Message 4 of 7 (2,024 Views)
Re: XLINE; BUGGGED?
08-19-2010 10:13 AM in reply to: randomnewb
Thayne Wickam
Support Specialist
Product Support
Active Contributor
randomnewb
Message 5 of 7 (2,020 Views)
Re: XLINE; BUGGGED?
08-19-2010 10:16 AM in reply to: thayne.wickam
I know, and i do appreciate it, like i said, its good to know someone from A.desk is there for me
Valued Contributor
Mark_Richards
Message 6 of 7 (1,342 Views)
Re: XLINE; BUGGGED?
01-15-2013 04:26 PM in reply to: randomnewb
Bumping this so maybe someone at Autodesk will pick up on it. AND MAYBE FIX IT :smileyhappy:
This is definately broken.  It's all about weather you have ther perpendicular option ticked in osnaps.  The broken part is that you can toggle (F3) Osnaps off and the behavior doesn't go away until you go in and un-tick perpendicular.
Makes me avoid XLINE.
This problem is not related to ortho mode being on as shown in the video above.
See this thread...
http://forums.autodesk.com/t5/AutoCAD-2010/xline-polyline-anomaly/td-p/2550096#.UPXwxmfK6Ng
Thanks.
New Member
ScottCS24
Message 7 of 7 (209 Views)
Re: XLINE; BUGGGED?
09-05-2014 08:12 AM in reply to: randomnewb
I also had this issue in AutoCad LT 2015 it seems that whatever the bug, if both perpendicular and tangent are selected in object snap, the bug disappears.  So if you use perpendicular alot, and hate to turn it on and off all of the time, just turn on tangent.  Hope this helps anyone with the same issues.
