Yes I'm placing my Wipeouts in paperspace, over a viewport. the vieport border is hidden by the wipeout, but the model space bleeds thru the wipeout. I'm haveing a bit of a time trying to find the variable thats allowing that to happen.
check in the plot-dialog the checkbox for "Plot Paperspace last", toggle it and try it again.
- alfred -
See attached, I left the WIPEOUT frame on for easier review: is this what you want?
Thanks for the examples. But my issue doesn't go as far as printing. In the live model I can see thru my wipeout which is active and in the forground on the sort order. It seems to work on every thing but the actual contents of the viewport. This is not normal, never had this issue before. and when i open a new drawing the sam issue is present. which leads me to believe it a veriable or system setting.
Mine was doing the same thing. It turned out that I had accidentally turned off plotting for that layer in the layer properties manager.
