AutoCAD 2010/2011/2012
Distinguished Contributor
thatcadguy
Message 1 of 7 (2,077 Views)
Wipeout in paperspace doesn't cover modelspace entities in viewports
2077 Views, 6 Replies
02-16-2011 01:12 PM
Have a drawing, I go to paperspace and draw a wipeout over a viewport. The modelspace entities shine through even after draworder, etc. If I make a new drawing and do the same thing, it works as intended. Is there some obscure system variable or something?
Kate_LT
Message 2 of 7 (2,056 Views)
Re: Wipeout in paperspace doesn't cover modelspace entities in viewports
02-16-2011 03:08 PM in reply to: thatcadguy
Is Plot Paperspace Last checked in your page setup? Not sure if it affects pre-plotted display, but might be worth a shot.
Kate Morrical
Technical Marketing Manager
LT Unlimited
thatcadguy
Message 3 of 7 (2,034 Views)
02-17-2011 05:17 AM in reply to: Kate_LT
Thanks, I'll give it a shot.
*Pro
nestly
Message 4 of 7 (2,025 Views)
02-17-2011 07:18 AM in reply to: thatcadguy
According to Lynn Allen, Text Masks (wipeouts) in PaperSpace can not be used to mask Modelspace objects.
http://lynn.blogs.com/lynn_allens_blog/2011/01/an-autocad-hip-tip-on-textmask.html
JGerth
Message 5 of 7 (2,021 Views)
02-17-2011 07:33 AM in reply to: nestly
workaround could be to create a solid hatch in paperspace  to hide what you don't want to see, and set the color of the hatch to TrueColor 255,255,255
thatcadguy
Message 6 of 7 (1,981 Views)
02-18-2011 07:52 AM in reply to: nestly
@nestly: Try it, it works in a new drawing.
Thanks for the solid hatch suggestion, I'll try that.
New Member
shawnk18
Message 7 of 7 (365 Views)
05-19-2014 02:03 PM in reply to: thatcadguy
Go to your properties cause Im guessing you have a transparency issue make sure you have it show 0.
