AutoCAD 2010/2011/2012
Member
0 Kudos
Post 1 of 8
While being panned, a drawing changes its color.
751 Views, 7 Replies
09-01-2010 12:20 PM
Guys,
When I start panning a drawing in AutoCAD 2011, it immediately assumes a color of the background. Is there any way to prevent that from happening (so a drawing stays as it is while being panned)? Thanks.
http://docs.autodesk.com/ACD/2011/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-4eb0.htm
that should get it taken care of for you, if not let us know
Active Contributor
2 Kudos
Post 2 of 8
Re: While being panned, a drawing changes its color.
09-01-2010 01:19 PM in reply to: alextsybin5011
what element of the drawing is it thats changing color?
Valued Mentor
8 Kudos
Post 3 of 8
What you are asking doesn't make much sense. Or, at least, my feeble brain can't make sense of it.
What exactly is it that 'assumes a color of the background'?
Are you saying the objects (lines and circles, etc.) of the drawing become the same collor as the background and you can no longer see them?
Steven Elliott
When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
Member
0 Kudos
Post 4 of 8
09-01-2010 01:26 PM in reply to: alextsybin5011
I am working with map images creating pavement marking plans. The background color is currently grey. When I start panning, the map itself becomes grey, too. All I can see is whatever I drew - solid and broken white line and whatever.
Member
0 Kudos
Post 5 of 8
09-01-2010 01:28 PM in reply to: randomnewb
The background of the drawing itself. So I am able to see only what I put on it.
Active Contributor
2 Kudos
Post 6 of 8
09-01-2010 02:13 PM in reply to: alextsybin5011
that is not the drawing backround, just fyi. the RASTER IMAGE you have inserted is the object thats becomming transparent, just to clarify.
im not sure how to maintain images while panning
Active Contributor
2 Kudos
Post 7 of 8
09-01-2010 02:46 PM in reply to: alextsybin5011
Member
0 Kudos
Post 8 of 8
09-02-2010 05:17 AM in reply to: alextsybin5011
It worked! Everything's fine now. The image stays as it was, when I pan it.
Thank you very much!
