AutoCAD 2010/2011/2012
0 Kudos
Post 1 of 5
where to locate the acad.exe for standard AutoCAD
787 Views, 4 Replies
12-18-2012 02:54 AM
Im trying to create an install application of all our customisations so that our staff can take home the blocks and lines and texts and macros lisp/ fas ect.. that we use at work.
the issue though is we use Architectural suite 2012 at work so when i need to programaticaly (windows batch) find the acad.exe for the standard eddition of autocad 2012 (which most staff use at home) i cant figureout wher it would be. In all previous versions the acad.exe was found in C:\Program files\AutoCAD 20xx.... where as with architectureal 2012 its found in C:\Program files\Autodesk\AutoCAD architectural suite 2012.....
as can be noted there is a suden change to the directory structure with the advent of the folder AUTODESK. thus which is correct
1: C:\Program files\ AutoCAD 2012\acad.exe
or
2: C:\Program files\ AutoDesk\AutoCAD 2012\acad.exe
473 Kudos
Post 2 of 5
Re: where to locate the acad.exe for standard AutoCAD
12-18-2012 04:57 AM in reply to: The_Caddie
In most cases, this will return the correct path
(findfile "Acad.exe")
0 Kudos
Post 3 of 5
12-18-2012 05:15 AM in reply to: The_Caddie
Yes I know that however i need to know  this before starting AutoCAD up, or in my case without even having AutoCAD 2012 STD installed on my pc.
501 Kudos
Post 4 of 5
12-18-2012 07:39 AM in reply to: The_Caddie
As far as I know, blocks, linetypes, etc. have no dependance on the acad.exe location.  There's even less dependance if they are going to be working on vanilla AutoCAD rather than the Architectural vertical.
Is there some special reason you need this particular location?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
1,210 Kudos
Post 5 of 5
12-18-2012 10:11 AM in reply to: The_Caddie
At least there is a default path for installation, but every admin may have it's own ideas and my install it to any self-created folder.
The option you may have is the registry, there you can find on many places pointers to ACAD.EXE, but also be careful if there are more than one version/release of AutoCAD is installed.
And please see the post from dgorsman ==> the place you use for symbols does not depend on the folder of ACAD.EXE, you just have to add a path to the list of supportfolders in the AutoCAD-profile(s).
- alfred -
Alfred NESWADBA
