AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 3
When trying to get ribbon to load, error.............
536 Views, 2 Replies
10-10-2012 06:33 AM
I work at a place where we use autocad, everywhere... And I'm in IT and i've been struggling with this for a day now. I got 2009/2011 to work, but when i try to get 2010 to work, it just doesnt want to cooperate. Now when i used to start it up a proxy graphics thing would pop up, and i figured out how to turn that off, but then no ribbon loads.
So i go to the command line and type in ribbon, and i get an error:
"Unhandled exception has occurred in a component, in your application. if you continue, the app will ignore this error and attempt to continue.
Object reference not set to an instance of an object"
and here are the details
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.LoadRibbon()
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.Initialize()
at Autodesk.AutoCAD.Ribbon.RibbonServices.CreateRibbonPaletteSet()
at Autodesk.AutoCAD.Ribbon.Commands.Ribbon()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5448 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 18.0.0.0
Win32 Version: 18.0.309.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/AcdbMgd.DLL
msvcm90
Assembly Version: 9.0.30729.6161
Win32 Version: 9.00.30729.6161
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll
System
Win32 Version: 2.0.50727.5453 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Xml
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5011 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
AdWindowsInterop
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/AdWindowsInterop.DLL
AdWindows
Assembly Version: 2.1.0.0
Win32 Version: 2.1.123.309
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/AdWindows.DLL
acmgd
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/acmgd.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/AcWindows.DLL
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.5420 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
AcWindows.resources
Win32 Version: 18.0.55.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/AcCui.DLL
AeccUiWindows
Assembly Version: 7.0.3025.0
Win32 Version: 7.0.3025.0
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/AeccUiWindows.DLL
AeccUiWindows.resources
Assembly Version: 7.0.1289.0
Win32 Version: 7.0.1289.0
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/en-US/AeccUiWindows.resources.DLL
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AcLayer
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/AcLayer.DLL
System.Windows.Forms
Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
AcLayer.resources
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/en-US/AcLayer.resources.DLL
System.Web.Services
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
ManagedMC3
Assembly Version: 2.20.0.0
Win32 Version: 3.14.1
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/ManagedMC3.DLL
WindowsFormsIntegration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsFormsIntegration/3.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
wpgjhhpx
AcCommandToolTips
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/AcCommandToolTips.DLL
AcCommandToolTips.resources
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/en-US/AcCommandToolTips.resources.DLL
VerticalTips
Assembly Version: 13.0.141.0
Win32 Version: 13.0.141.0
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/VerticalTips.DLL
AeccUiTooltipContent
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/AeccUiTooltipContent.DLL
AeccUiTooltipContent.resources
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil%203D%202010/en-US/AeccUiTooltipContent.resources.DLL
UIAutomationProvider
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
if anyone could help, that'd be awesome
1,589 Kudos
Post 2 of 3
Re: When trying to get ribbon to load, error.............
10-12-2012 05:53 AM in reply to: natec16
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Reinstall (for XP/Vista users): http://usa.autodesk.com/getdoc/id=TS75218
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
0 Kudos
Post 3 of 3
10-17-2012 07:13 AM in reply to: natec16
I had the batch plot on the ribbon bar and have been using it for the last day or so.  After reading several blogs about it, I realized that the ribbon was the problem, so I got rid of the batch plot on my ribbon.
When I tried to open the file again, it gave me a fatal error.  ACAD then took a dump.  I recovered the file, and everything seems to be ok now.
I don't know if that helps you, but it resolved my problem.
Good Luck!
katnavar13
