AutoCAD 2010/2011/2012
Distinguished Contributor
11 Kudos
Post 11 of 20
Re: What is the most efficient way to draw a line inclined by
04-19-2012 07:10 AM in reply to: JamaL9722060
I like it! This is the sort of thing that I expected to find as an improvement. I normally run with Polar Tracking turned off so I didn't see the benefit until now. Thanx.
This is a better solution for you Jamal, type DSETTINGS, click the lower of both of the two radio buttons on the right of the Polar Tracking tab and supply an increment angle that works for you.
9 Kudos
Post 12 of 20
04-19-2012 01:17 PM in reply to: dbanaszak
Thank you guys for the help. This is really a great tool.
Do you have any idea how to let the tip reads the angle “clockwise”. For example, in the screenshots below, I need the tips to read 30 but not 330. Is that possible?
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
473 Kudos
Post 13 of 20
04-19-2012 01:30 PM in reply to: JamaL9722060
JamaL9722060 wrote:
What is the most efficient way to draw a line inclined by particular angle from another line?
Polar tracking, relative to last segment? No construction lines needed.
473 Kudos
Post 14 of 20
04-19-2012 01:35 PM in reply to: JamaL9722060
Set ANGDIR to 1
This should be the result
9 Kudos
Post 15 of 20
04-19-2012 01:44 PM in reply to: rkmcswain
many thanks rkmcswain. now it works fine.
best
Jamal
Firefox 20.0,
Kaspersky 2013.
9 Kudos
Post 16 of 20
04-20-2012 01:29 AM in reply to: rkmcswain
I’m again struggling with another issue!
I wanted to sketch up the polygon (existing) shown in the screenshot below, but couldn’t figure out the best way to approach it. This time:
  1. The given angle is the interior,
  2. The angle is given in deg/min/sec
How can I draw such given polygon efficiently?
Many thanks
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
1,210 Kudos
Post 17 of 20
04-20-2012 01:37 AM in reply to: JamaL9722060
do first a sketch of the figure and then place the contraints for distance and angle.
What I have not tried now is if you can input the angle-value like you show the angular dimension with ° ' "
- alfred -
Alfred NESWADBA
9 Kudos
Post 18 of 20
04-20-2012 02:02 AM in reply to: Alfred.NESWADBA
Brilliant Alfred. This is a quite satisfactory solution.
As you have already indiacted, what is missing is to represent the angle in deg/min/sec
Many thanks
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
9 Kudos
Post 19 of 20
04-23-2012 04:08 PM in reply to: Alfred.NESWADBA
Hi Alfred,
A colleague indicated that changing the drawing units will solve this issue.
Please, have a look on the screenshot below
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
1 Kudo
Post 20 of 20
05-22-2013 06:42 AM in reply to: CSEnginuities
Thanks Clara,
This is a great simple solution for what I was looking for.
