AutoCAD 2010/2011/2012
9 Kudos
Post 1 of 20
What is the most efficient way to draw a line inclined by
5784 Views, 19 Replies
04-17-2012 12:59 PM
What is the most efficient way to draw a line inclined by particular angle from another line?
I wanted to draw a line inclined by particular angle from another line but couldn’t get the best way to do that.
For example, in the screenshot below, I wanted to draw a line inclined by 60º from an existing line but couldn’t approach the best way to approach it.
How can I draw this line efficiently?
Thank you for the help
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Distinguished Contributor
11 Kudos
Post 2 of 20
Re: What is the most efficient way to draw a line inclined by
04-17-2012 06:42 PM in reply to: JamaL9722060
Jamal, there may be newer drafting aids to accomplish this task, but I would Array the existing line 120 degrees and then draw a Circle with the requisite length of the line as its radius, Extending or Trimming it to get the correct length.
594 Kudos
Post 3 of 20
04-17-2012 08:55 PM in reply to: dbanaszak
There is No newer drafting aids to accomplish this task.
Use snapang
Valued Mentor
35 Kudos
Post 4 of 20
04-18-2012 02:24 AM in reply to: Patchy
or usb x axis lines up with the first line  in the xy plane  and draw the second at 60 degrees
Valued Mentor
35 Kudos
Post 5 of 20
04-18-2012 02:57 AM in reply to: parkr4st
i mean ucs, usb. :smileyhappy:
dave
Distinguished Mentor
109 Kudos
Post 6 of 20
04-18-2012 07:37 AM in reply to: JamaL9722060
If you know the lengths and angles you want, why not just type it in from the command line?
Line command ► Select start point ► @ x" < x°
Don't end the line command there, but just keep going by entering more distances (@) and more angles (<).  If you're not effecient with calculating angles on the fly in your head, though, then it may not be a good solution.
______________________________________________________________________________________________________________________________________________________
System specs: AutoCAD 2015 64-bit SP2, Windows 7 64-bit SP1, Intel Core i7-2600K, 16GB RAM, Crucial M4 SSD, AMD FirePro V4900, 2 Dell Monitors (2560x1600)
213 Kudos
Post 7 of 20
04-18-2012 08:42 AM in reply to: JamaL9722060
I prefer rotating the UCS (as mentioned earlier), I have UO set to UCS, Object, pick the object and start drawing.  I have UW set to UCS, World to get back.
Once the UCS is set, start the line, snap to the endpoint, you can use Polar at this point or type <55, enter, then specify length, among other methods.
Tip - you can set the angle increment angle in Polar to 1 if you want, or 0.5, etc, you don't have to use the predefined angles.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
11 Kudos
Post 8 of 20
04-18-2012 11:48 AM in reply to: JamaL9722060
Patchy, I wasn't sure if anything new had been added to accomplish the task, and I tend not to mess with UCS unless I'm doing 3D work - I was formerly a Civil designer but it's been three years since I've slung a vector in anger to earn a paycheck. I'm back in school and HAD to take a graphics class (easy A) to satisfy pre-eng requisites. The solid modeling and the Inventor stuff has been fun, unfortunately they don't teach Civil3D. I asked questions earlier and am paying it back where I think I can be helpful, but don't be afraid to overrule me, I only think I know everything.
9 Kudos
Post 9 of 20
04-18-2012 12:22 PM in reply to: dbanaszak
Thank you guys for the contribution and feedback. Your comments are quite helpful.
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
Active Contributor
8 Kudos
Post 10 of 20
04-18-2012 05:31 PM in reply to: JamaL9722060
Adjust your Polar Tracking settings from "absolute" to being "relative" to the last line drawn.
Clara
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
