AutoCAD 2010/2011/2012
2 Kudos
Post 1 of 12
What is the difference between World UCS and Top UCS
754 Views, 11 Replies
02-15-2013 08:43 AM
Question - What is the difference between the world UCS and the top UCS?
I am working in a faily large model and when I have the UCS set to world and do the ID command I get the correct coordinance. However when I am in a plan view and UCS is set to top the coordinance come in roughly 600 feet different. Can anyone tell me how to set the UCS so that coordinance will be the same no matter what UCS is being used? Or explain why this would be?
Thank you!
10 Kudos
Post 2 of 12
Re: What is the difference between World UCS and Top UCS
02-19-2013 06:06 AM in reply to: ryan0416
The TOP UCS is a relative UCS. Aty the start the TOP and WCS are the same.
Lets say for example that you have a box drawn nice and square to the WCS. if you were to rotate the view to get a 3D look at the box you may wish to draw something not on the XY plane. so we use the UCS command and define a new reference XY plane. The TOP UCS is now planar with the current XY plane and also the TOP USC is no longer planar with the WCS (which is CONSTANT for a drawing).
Hence the TOP UCS is set by using the UCS command and is relative
HTH
10 Kudos
Post 3 of 12
02-19-2013 06:11 AM in reply to: ryan0416
Also if you have set a custom UCS which happens to be co-planar with the WCS then the WCS and TOP ucs's will have different origin points and thus different ID values
2 Kudos
Post 4 of 12
02-19-2013 06:43 AM in reply to: Nik-D
Ok, so if I am getting different coordinates when I ID a particular point how do I change the UCS so that no matter what view I am in I will get the same coordinates? The only way I was able to solve the issue was to start with a fresh file.
Thanks for your previous response!
10 Kudos
Post 5 of 12
02-19-2013 08:04 AM in reply to: ryan0416
set your UCS to world - Type - USC (enter) W (enter)
Set the WCS current and regenerate layout - Type - PLAN (enter) (enter)
Draw a horizontal XLINE through the current origin
type UCS, then select the origin followed by some point on the XLINE to the RHS.
Your TOP UCS should now be in the correct location
2 Kudos
Post 6 of 12
02-19-2013 08:07 AM in reply to: Nik-D
Ok, Thanks! I will give that a try on my old model. I appreciate the help!
0 Kudos
Post 7 of 12
05-29-2013 11:11 AM in reply to: ryan0416
It's easy enough to temporarily move the UCS anywhere I'd like it to be, but the Top UCS resets to a point different from the World UCS every time I set the view back to Top.
what I'd like to understand is why the Top UCS is different from World in this particular drawing, and how I reset it to be the same as World UCS, permanently.
*Expert Elite*
312 Kudos
Post 8 of 12
05-29-2013 06:52 PM in reply to: ohnoezitasploded
what is UCSFOLLOW set to?
0 Kudos
Post 9 of 12
05-30-2013 10:31 AM in reply to: ryan0416
I've set it to both 1 and 0, it doesn't affect this behavior-- i.e. when I set UCS to Top, it still moves the base point away from the World UCS.
Valued Mentor
11 Kudos
Post 10 of 12
06-02-2013 01:52 PM in reply to: ryan0416
as others have said , if you are using ID to get coordinates, make sure you are always in the same coordinates system.
Be it either WCS  or another UCS , does not matter, as long as you do not change.
This way coordinates all have same origin .
WCS is the easiest :  just type ucs , and w  for World
if you use UCS , it can be saved. with the same command :  ucs , named and save
Post to the Community
New Post
