AutoCAD 2010/2011/2012
Member
0 Kudos
Post 1 of 7
What is the correct path to the ACAD help file?
663 Views, 6 Replies
02-03-2012 07:14 AM
I am going through the paths in the Files tab of my AutoCAD profile. I am looking for incorrect or non-existent paths, in hopes of speeding up ACAD.
Under "Help and Miscellaneous File Names" there is a path for "Help Location".
C:\Program Files\Autodesk\AutoCAD 2012 - English\help\index.html
When I attempt to browse the path on my PC, it can't be found. When I attempt to cancel my editing of the path, AutoCAD pops this dialog:
"Path does not exist: C:\Program Files\Autodesk\AutoCAD 2012 - English\help\index.html Are you sure you want to use this value?"
1,217 Kudos
Post 2 of 7
Re: What is the correct path to the ACAD help file?
02-03-2012 01:23 PM in reply to: jarsky
for me it's the correct path (except that I'm using the German version: "Deutsch") the default setting is:
C:\Program Files\Autodesk\AutoCAD 2012 - Deutsch\Help\index.html
and it finds the index.html in this folder.
- alfred -
Alfred NESWADBA
1,603 Kudos
Post 3 of 7
02-03-2012 03:35 PM in reply to: jarsky
Is the folder Hidden? you can't just simply "browse" to it.
Your HELP setup gets totally hosed if you invoked the "MIGRATE SETTINGS" option from an older autoCAD, or loaded an older AutoCADprofile, in 2012.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
0 Kudos
Post 4 of 7
02-03-2012 03:50 PM in reply to: jarsky
Hidden or not, if you enter a path in the address bar of a Windows window, you will be be taken to the destination (file or directory) specified.
As for the Migrate Settings question, I think I did use that tool, but why should my path match alfred.nedwasba's, yet he finds his help file there and I do not?
Mysteries.
Distinguished Mentor
45 Kudos
Post 5 of 7
02-03-2012 04:07 PM in reply to: cheapo
Isn't the help file online guys?
Might it trigger your browser and go to the website??
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://www.youtube.com/playlist?list=PLD9BF5D8FF70CD3DF&feature=view_all
1,603 Kudos
Post 6 of 7
02-04-2012 06:00 PM in reply to: cheapo
Time for a repair reinstall then: simple to do and quick/done by now.
1,603 Kudos
Post 7 of 7
02-04-2012 06:01 PM in reply to: ntellery
It's supposed to tap a local copy if the internet is dead: hence the problem I suspect.
