AutoCAD Forum
What happened to AM2DHIDE? AMSHIDE unavailable as well...
5 REPLIES 5
pete592
332 Views, 5 Replies
I am using AutoCAD Mechanical 2012, and I haven't used the command in a while, but now that I need the AM2DHIDE, it is now unlisted in the Modify menu and is "unknown" when entered.  I also saw AMSHIDE mentioned in Exchange, but it also is unlisted and "unknown."
What gives?
Is there something new and improved?
5 REPLIES 5
in reply to: pete592
What gives?
I'd say that your answer lies in the ACAD Mech forum.
steve216586
Make sure you didn't open a drawing with the Vanilla AutoCAD profile instead of Mechanical. It sounds like you may have. Or, you need to fix your installation of Mechanical, as nothing has changed through 2015 and those two commands still exist.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
pete592
in reply to: steve216586
That's the first thing I checked.  I am without a doubt using Mechanical.
steve216586
Repair/reinstall. )-:
GrantsPirate
Both commands are there in 2014M.  In the Ribbon go to the Home tab, Detail panel, AMSHIDE.
If you have autocomplete on type *hide* at the command line (include the asterisks) and you should see the commands.
I have 2014 but it should be very similar to 2012.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
”Boost
