good times over here
etransmit is not working, error says "Failed to load transmittal component: incorrect registry entry." ... googling this error, as enjoyable as it is, leads nowhere other than to "repair/reinstall Autocad" which I would do if I COULD FIND MY INSTALLATION DISK! which I cannot ...
is there any other command or way to achieve the same end result as the command etransmit? any workaround here please?
p.s. a clue as to why this is happening is that i had to uninstall civil 3d 2012 from this machine and that's when this started ...
Solved by jggerth. Go to Solution.
Hello
I imagine that you have a Civil 2012, but ...
You have which ACAD exactly (ACAD, LT, CIVIL, MAP, etc) ?
Which Version 2010/2011/2012 ?
32 or 64 bits ?
Win XP Pro / Seven ?
ETransmit stopped to run OK recently ??
Have you installed th SP1 or SP2 on your 2012 software ?
A few more Infos will be appreciated ...
Bye, Pat
Patrice BRAUD
Contact your Autodesk reseller and request replacement media, hopefully you still have your serial number and product code with the authorization email adesk sent you when you authorized the software.
or try http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18316170&linkID=9240617
Hello
You could try to REPAIR your ACAD 2010 Install !
Bye, Pat
Patrice BRAUD
thanks guys, however, I need a solution TODAY because I have to send a file to a client and etransmit is not working, there must be another way to pack a file with everything that's needed?!
Workaround? open XREF manager and copy down all the files, including nested/image/pdf/dwf etc. Then run the Style command and see if there are any non-standard font files in use. Then include your ctb/stb -- copy all to a separate folder and zip em up
ctb & stb are the extensions used for pen tables in plotting without including those (presuming you are using plot styles at all) it's difficult for the recipient to guess what a line is supposed to look like on paper. (Is blue supposed to plot out fat, thin, medium?)
standard fonts would be those installed either with an basic Windows setup, or a plain stock AutoCAD install. If you've added & are using non-standard fonts, the the recipient's version will substitute fonts to display text using something they have instead of something they don't have.
for maximum portability between organizations, it's safest to stick with RomanS as an shx 'stroked' font, and Arial or Calibri as the TTF font. If your drawing uses anything else, it may be a non-standard.
You can lok at the font files being used by running the STYLE command and picking through the named styles to see what's required. Or you can use the -STYLE (with a hyphen in front, to get a screen listing all of the style in use with their fonts. that output will look like:
Command: -style
Enter name of text style or [?] <Arial>: ?
Enter text style(s) to list <*>:
Text styles:
Style name: "Arial" Font typeface: Arial
Height: 0'-0" Width factor: 1.0000 Obliquing angle: 0.0000
Generation: Normal
Style name: "Legend" Font typeface: Calibri
Generation: Normal
Style name: "romans" Font files: romans.shx
Height: 0'-0" Width factor: 0.9000 Obliquing angle: 0.0000
Generation: Normal
Also - check the linetypes in use -- and see if any use complex characters that may require a shape file to create them. If they do, and you don't supply it the recipient will get an alert about a missing shx file.
