AutoCAD Forum
Weld Symbol generator
4 REPLIES 4
zippy216
3795 Views, 4 Replies
Doe s anyone know a a weld symbol generator that will allow stacked fractions for the size?
4 REPLIES 4
Jonathan3891
in reply to: zippy216
Visit my blog here and go to the lisp library. I have a weld symbol generator that works great! it has a menu that allows you to select your weld info and the arrow/text uses your dimstyle.
I cant remember if it allows stacked fractions. But its worth a try.
Jonathan Norton
Blog | Linkedin
zippy216
What do I need to do to get it to run? Where should I copy the files from the .zip file?
Raymond G. Kohan
Civil/Structural Designer
[cid:image001.jpg@01CEAEDC.7185DF00]
1000 Omega Drive, Ste. 1590
Pittsburgh, PA 15205
412.706.5953 (OFFICE) 412-489-6598 (FAX)
rkohan@csdengineers.com
www.csdengineers.com
zippy216
Spoiler
I got it to run but all of the fields come in with a "0".  ANy ideas why?
Spoiler
Jonathan3891
Did you follow the description??
This lisp will launch a menu allowing the user to select weld info.
This system works off dimension style!
**Note**
You will have to have a support path pointed to the location of the Weld.DCL
Jonathan Norton
Blog | Linkedin
”Boost
