AutoCAD 2010/2011/2012
Active Member
SolarCadTech
Message 1 of 6 (728 Views)
Viewport of PaperSpace (viewport of a Layout) in another Layout
728 Views, 5 Replies
08-03-2011 07:14 AM
i need to insert an updateable thumbnail image of a layout into other layouts.
is there a way to create a viewport that opens a portal into paperspace / Layouts rather then model space ?
thanks,
autocadLT2011
i7-M620@2.67GHz
8GB ram
64bit
pendean
Message 2 of 6 (711 Views)
Re: Viewport of PaperSpace (viewport of a Layout) in another Layout
08-03-2011 08:13 AM in reply to: SolarCadTech
Paperspace Layouts are not accessible in viewports or Xrefs or blocks etc.
May I ask what your final intent is? There may be other options.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
SolarCadTech
Message 3 of 6 (703 Views)
08-03-2011 08:25 AM in reply to: pendean
My Final Intent is to be able to show a thumbnail of a layout on the rest of the drawings set (i use the layout  tabs to create my set). so this is all happening within a single drawings file.
for example: on sheet/tab #2, i set up a combination of objects/blocks, and i want to see a thumbnail of that composition on other pages/tabs in that set.
it will take too long to copy the reference layout (sheet/tab #2) into paperspace in order to acomplish this. and it will "de-automate" the process as well.
thanks,
autocadLT2011
i7-M620@2.67GHz
8GB ram
64bit
pendean
Message 4 of 6 (695 Views)
08-03-2011 08:39 AM in reply to: SolarCadTech
>>>... i set up a combination of objects/blocks...<<<
So you are drafting/drawing in paperspace?
Active Member
SolarCadTech
Message 5 of 6 (691 Views)
08-03-2011 08:49 AM in reply to: pendean
that specific sheet is assembaled/drawn in paperspace for work-flow purposes.
autocadLT2011
i7-M620@2.67GHz
8GB ram
64bit
pendean
Message 6 of 6 (678 Views)
08-03-2011 10:50 AM in reply to: SolarCadTech
You can only use Modelspace content in viewports as noted in my first email: items drawn in paperspace are stuck there out of reach in that individual file.
