AutoCAD 2010/2011/2012
Distinguished Contributor
0 Kudos
Post 11 of 23
Re: VIEWPORT COLOR OVERRIDE NOT WORKING
08-12-2011 06:54 AM in reply to: azrdgldr
I just tried on my neighbors machine and it works fine. Is there a variable setting that could have this turned off? My SP's are up to date.
33 Kudos
Post 12 of 23
08-12-2011 07:04 AM in reply to: chaz
VPLAYEROVERRIDES, it is a read only variable and VPLAYEROVERRIDESMODE = 1
0 Kudos
Post 13 of 23
08-12-2011 07:51 AM in reply to: azrdgldr
I just finished a REPAIR install and its working now. I tried a neighbors machine and it was working so I narrowed it down to my particular machine.
33 Kudos
Post 14 of 23
08-12-2011 07:57 AM in reply to: chaz
Quote: "I narrowed it down to my particular machine"
Yeah Right!!!!!  Yeah!!!! Yeah!!!! I know, the check is in the mail.  Have a good one.
0 Kudos
Post 15 of 23
09-27-2011 11:26 AM in reply to: chaz
This is happening again in another drawing. I REALLY dont want to reinstall again.
Active Contributor
1 Kudo
Post 16 of 23
05-25-2012 02:21 PM in reply to: azrdgldr
I am getting the same problem.
In summary I would like to x ref a plan drawing and make it grey within a viewport so I can do a lighting layout over the top of a greyout drawing.
As you will see 99% of the lines turn to grey when I change their viewport properties. However the lines that have been changed in the original drawing from out of the normal Bylayer properties do not go to the desired grey.
The reason why I have changed these lines in the original drawing is because I want the lines a heavier weight.
Really appreciate any advice.  I have tried it on the other lapotp in office and does not work on that either.
CHECK THE SCREEN CAST HERE ....     http://screencast.com/t/ty6bjPmZ
*Pro
169 Kudos
Post 17 of 23
05-26-2012 05:28 AM in reply to: HAMJAM
1) The layers displayed in your Layer Manager, are filtered to show only the xref layers, so what you did in the video would not have changed the VP color for any non-xref'd objects.
2) If those objects already have color property over-rides assigned, they will not change color when changing the layer color.
Active Contributor
1 Kudo
Post 18 of 23
05-26-2012 06:46 AM in reply to: nestly
Thanks very much for your reply.
"1) The layers displayed in your Layer Manager, are filtered to show only the xref layers, so what you did in the video would not have changed the VP color for any non-xref'd objects." Yes this is what I wanted.  So just to be clear I want all xref layers to be grey.
2) If those objects already have color property over-rides assigned, they will not change color when changing the layer color. Yes the lines with object not coming out in grey already have the colour overides changed in the original drawing.  This is because I want the lines to be heavier in the original drawing. As such I do not want to have to change the overides in the original drawing but when I referrence the drawing into this new sheet I want them to come out grey.??
Any idea on how best to achieve this?
*Pro
169 Kudos
Post 19 of 23
05-26-2012 08:09 AM in reply to: HAMJAM
HAMJAM wrote:Yes the lines with object not coming out in grey already have the colour overides changed in the original drawing.  This is because I want the lines to be heavier in the original drawing. As such I do not want to have to change the overides in the original drawing but when I referrence the drawing into this new sheet I want them to come out grey.??
If they are not BYLAYER in the original (xref) I don't believe you can override their color.  I would put those objects on thier own layer in the original drawing, set their properties back to BYLAYER, and make that layer any color or lineweight you choose.
If just for plotting, you could use plot styles to "override" the display color.
Active Contributor
1 Kudo
Post 20 of 23
05-26-2012 09:45 AM in reply to: nestly
Good point I will try use tthe plot styles to "override" the display color and make everything turn grey.
I still do not understand the logic of why Autocad would not allow you to override all elements in the viewport as, after all it is a 'viewport overide'?
Thanks all the same for your help.
