How do I switch off and on the view controls menu, which sits at the top right of the screen?
Also, when I click on the "Viewcube" icon, the cube does not appear. Is it hidden, or moved off-screen somehow?
Solved by doni49. Go to Solution.
Uncheck the following (type OPTIONS to get this dialog).
Don Ireland
Engineering Design Technician
Do you mean this? If so, there is a little X (in the yellow circle). If you click the X, it'll close.
EDIT: That's also controlled by the variable NAVBARDISPLAY.
Don Ireland
doni49 led you in the righ direction.
A shortcut is to go to the "View" tab.
On the right, click on "User Interface"
There you can turn-on-&-off the Navigation Bar.
Hmmm.... A shortcut usually involves a quicker way to get where you want to be. What's quicker than clicking the little x on the navbar?
Don Ireland
oh that makes sense. Yes that's a quick & easy way to turn it on -- a lot of people would have trouble remembering the sysvar name.
Don Ireland
You're right about having trouble remembering names.
The last I heard, the longets AutoCAD command is "EXTERNALREFERENCESCLOSE" at 23 characters to type.
2nd longest may be "BAUTHORPALETTECLOSE" at 19 characters.
But who's counting?
Read Y'all Later -KLYPH
