can't find setup for AutoCAD 2011-VBA-Enabler on redesigned autodesk-website.
Are enablers for AutoCAD 2013 and earlier really no longer available?
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770215#section3
Thanks for your support
Solved by rkmcswain. Go to Solution.
It is very clearly stated "As of January 31, 2014, Autodesk is no longer authorized to distribute VBA 6 or earlier versions of VBA for use with Autodesk AutoCAD and other Autodesk products."
You may be able to find the download somewhere else. The name of it is autocad2011vbaenabler64.exe
