AutoCAD 2010/2011/2012
New Member
michellemcpeek6324
Message 1 of 19 (4,511 Views)
Using Windows Explorer to Search for text in DWG files
4511 Views, 18 Replies
05-16-2011 12:30 PM
Hello;
We are running Autocad 2012 (64 bit) on Windows 7. Does anyone know how to get Windows Explorer to search for text inside of DWG files?
Sincerely;
Michelle
3wood
Message 2 of 19 (4,487 Views)
Re: Using Windows Explorer to Search for text in DWG files
05-17-2011 05:26 AM in reply to: michellemcpeek6324
As far as I know, Window can perform content search in some old version of dwg files such AutoCAD 2004.
You can save a dwg file in different versions and test.
3wood
CAD KITS
New Member
michellemcpeek6324
Message 3 of 19 (4,459 Views)
05-17-2011 05:18 PM in reply to: 3wood
Thankyou for the suggestion - tried several different DWG versions and found no joy....looking for more ideas.
Sincerely;
Michelle
Employee
Craig.Godfrey
Message 4 of 19 (4,455 Views)
05-17-2011 06:01 PM in reply to: michellemcpeek6324
Michelle,
Have you tried using Content Explorer which is new in 2012? It allows you to search for various objects within a dwg file such as text, blocks, attributes, layers, dimensions, etc. You can find it in the Plug-Ins tab or by typing contentexplorer in the command line. Once you configure Content Explorer to watch a folder that contains your design files it will index them and you can then search for your information.
There are a few videos on Exchange that show what you can do with Content Explorer.
Craig S. Godfrey
Software QA Engineer
dseaton
Message 5 of 19 (4,124 Views)
04-08-2012 12:19 PM in reply to: Craig.Godfrey
Thank you Craig. Found the text I wanted in my drawing files. Lot easier than doing it from Win 7 Explorer!!!
Active Contributor
donjacobsen
Message 6 of 19 (3,629 Views)
10-15-2012 09:35 AM in reply to: Craig.Godfrey
Contentexplorer is good but it's very limited in functionality.  I tried to use it but it does not allow network folders.  To me this is very odd, most companies put their drawings on network folders.
Is there any other way of searching for text inside of a drawing?
Don
Alfred.NESWADBA
Message 7 of 19 (3,627 Views)
10-15-2012 09:38 AM in reply to: donjacobsen
As long as the server has a Windows operating system you can install the Content-Explorer service on every server and connect to this service then from your workstation.
- alfred -
Alfred NESWADBA
Active Contributor
donjacobsen
Message 8 of 19 (3,619 Views)
10-15-2012 09:50 AM in reply to: Alfred.NESWADBA
Thanks for the info Alfred.  I guess I need to get with my IT Dept to get this done.
Wish me luck - lol.
Don
Alfred.NESWADBA
Message 9 of 19 (3,615 Views)
10-15-2012 10:05 AM in reply to: donjacobsen
>> Wish me luck
I do :smileywink:
- alfred -
Alfred NESWADBA
Valued Mentor
TerryDotson
Message 10 of 19 (3,607 Views)
10-15-2012 11:55 AM in reply to: donjacobsen
Take a look at the DwgSearch tool in DotSoft's ToolPac, it will let you search DWG files without needing to build external indexes or anything running on a server, etc.
