I started by using the function (vlr-acdb-reactor "FixLastEntity" '((:vlr-ObjectAppended . fixlastentity)))
The purpose was to have a function that would change the layer or other properties of the last created entity.
If I were to change the entity by using lisp to change the entities list and use entmod, Autocad would crash.
I then tried to use the command line. It seemed to execute the command, but the entitiy did not change.
If I were to copy paste the command from the lisp file to the command line, it works just fine.
anybody have any ideas?
Decker Hi,
in the callback function (of reactors) you can not use (command) function
instead you should use ActiveX functions (vlax-xxxxx)
Moshe
Thanks for the input. I have reconfigured the lisp but now i am having another problem, maybe 2.
I start with a clean file
load the lisp
when i create an entitiy, it seems to want to execute but I get the error " VL-DATA#<VLR-AcDb-Reactor>no function definition:"
and I get the error 13 times
like this
Dimension text = 15'-10 5/16"#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA#<VLR-AcDb-Reactor>no function definition: VL-DATA
here is a portion of the lisp...
;setup and initialize the reactor
;load reactor functions
(vl-load-com)
; remove existing reactors
(vlr-remove-all)
;setup reactor
(vlr-acdb-reactor "Entity Update" '((:vlr-objectAppended . appobjupdate)))
(defun appobjupdate (CallingReactor CommandInfo / ObjType)
; (princ (strcat "\nSymbol Name: " (vl-symbol-name (vlr-type CallingReactor)))<------even though I am using some downloaded code this fails on load
(princ (strcat "\nReactor Data: " (vl-data CallingReactor)))
(princ (strcat "\nCallBack List: " (car (vlr-reactions CallingReactor))))
; (princ (strcat "\nEvent Reactor: " (vl-symbol-name (vlr-type CallingReactor)))<------even though I am using some downloaded code this fails on load
(princ (strcat "\nCallBack Function: " (cdr(car (vlr-reactions CallingReactor)))))
; (setq ObjType (vlax-get-property EntName 'ObjectName))<------even though I am using some downloaded code this fails on load
(princ (strcat "\n" ObjType))
what am I doing wrong???
D
i'm sorry i now getting what you after...
to change an object property right after it added to the database is a tricky proccess
1. define (install) a database reactor
2. on (mos:OnObjectAppended) callback function you only save the ename of the object just appended
(modifing the object there will result an error cause autocad has opened it only for read)
here comes the trick...define a command reactor there that get's fire as soon the command that added the object is ended
3. on (mos:OnCommandEnded ) callback function you can modify the object properties freely there at the end
the command reactor is disabled and do some cleanup of global variables
careful: the layer you want to move the last object should be exist before you set it to the object
Chesrs
Moshe
(defun mos:OnCommandEnded (Reactor cmd^ / AcDbObject) (if (eq (vlr-data Reactor) "OnCommandEnded") (progn (setq AcDbObject (vlax-ename->vla-object *ename*)) (vlax-put-property AcDbObject 'layer "my layer") (vlax-release-object AcDbObject) ) ) ; disable reactor (vlr-remove *cmdReactor*) (setq *cmdReactor* nil) (setq *ename* nil) ) (defun mos:OnObjectAppended (Reactor data^) (setq *ename* (cadr data^)) ; install command reactor (if (not *cmdReactor*) (setq *cmdReactor* (vlr-command-reactor "OnCommandEnded" '((:vlr-commandEnded . mos:OnCommandEnded)))) ) ) ; install database reactor (if (not *acdbReactor*) (setq *acdbReactor* (vlr-acdb-reactor "" '((:vlr-objectModified . mos:OnObjectAppended)))) )
another question. What is the function of the mos prefix in the defun statement.
I have not seen this before and I have programming in Autocad off and on for a few decades.
Decker,
the 'mos:' is noting but a prefix to functions name
alot of time i found my self using the same functions with slightly differences and to avoid
running over i set a new uniqe prefix name especialy when using reactors and callback functions
Moshe
