AutoCAD 2010/2011/2012
Active Member
Maccadin
Message 1 of 4 (264 Views)
Updating all text to add 10 to the current value
264 Views, 3 Replies
10-07-2012 10:51 PM
To anyone who can help,
I have around 700 pieces of dtext that all need to have their values raised by 10 is there any easy way of doing this?
Thanks in advance,
Maccadin
Alfred.NESWADBA
Message 2 of 4 (260 Views)
Re: Updating all text to add 10 to the current value
10-07-2012 11:02 PM in reply to: Maccadin
If development of such tool is easy, then yes, there is an easy way getting that done :smileywink:
If you describe more about your type of text (DTEXT, MTEXT, dimension-text, block-attribute-text, LEADER-text, ...) and do these text-objects have some prefix or suffix, .... or when you upload a drawing maybe someone does it for you.
- alfred -
Alfred NESWADBA
3wood
Message 3 of 4 (249 Views)
10-08-2012 04:01 AM in reply to: Maccadin
Please try attached routine.
Settings as below:
You can search from left or right depending on what text string structure it is.
Active Member
Maccadin
Message 4 of 4 (198 Views)
10-10-2012 06:34 PM in reply to: Alfred.NESWADBA
The text was a mix of DTEXT and MTEXT with 2 decimal places, all the text had numerical values only. I found a lisp that ended up doing what i wanted.
Here it is for future reference. Thanks for replying.
(defun c:addn ( / ss)
(vl-load-com)
(if (and (setq ss (ssget "X" (list (cons 0 "*text"))))
(setq amt (getreal "\nPlease type the amount you would like to add: ")))
(progn
(mapcar '(lambda (z) (vla-put-textstring z (rtos (+ (atof (vla-get-textstring z)) amt) 2 3)))
(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
(princ)
EDIT: I missed that response ALTEXT is perfect! thank you so much.
