AutoCAD 2010/2011/2012
Valued Mentor
16 Kudos
Post 1 of 10
Unwanted Info & Options
134 Views, 9 Replies
04-20-2012 07:40 AM
When I move my cursor over an item, say a line, two overlapping squars appear.
If I try to select the line, Information, like "line" or options appear, like "Stretch".
Instead of "E" for "Erase", select Line, Enter, it takes a lot more extra steps before the command is finished.
What is this feature called?
I can't look it up in HELP if I don't know what it's called.
How can I turn it off?
Read Ya Later -KLYPH
473 Kudos
Post 2 of 10
Re: Unwanted Info & Options
04-20-2012 08:12 AM in reply to: KLYPHY
Selection Cycling
Also controlled by a status bar button.
Valued Mentor
16 Kudos
Post 3 of 10
04-20-2012 08:32 AM in reply to: rkmcswain
You had my hopes up.
But no matter which number I set "SELECTIONCYCLING" at, "0", "1", or "2", the Info Pane still come up besice the item.
Any other ideas?
Read Ya Later -Cliff
213 Kudos
Post 4 of 10
04-20-2012 10:12 AM in reply to: KLYPHY
The two squares indicate that Parametric Constraints have been added.  Maybe you have INFER button toggled on, lower left of screen, if showing icons down there then the button will look like the two boxes and cross hairs.
Use DELCONSTRAINT (from command line) or from Ribbon to remove a lot of them quickly.
GRIPMULTIFUNCTIONAL is the setting for the other part, but I would leave that on personally, it gives you quick access to modify the line by stretching or lengthening, as an example.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
473 Kudos
Post 5 of 10
04-20-2012 11:14 AM in reply to: GrantsPirate
That depends on which icon the OP was referring to.
This one is for constraints
This one is for Selection Cycling
473 Kudos
Post 6 of 10
04-20-2012 11:16 AM in reply to: KLYPHY
KLYPHY wrote:
... the Info Pane still come up besice the item.
Do you mean this?
Valued Mentor
16 Kudos
Post 7 of 10
04-20-2012 11:39 AM in reply to: rkmcswain
The Icon was for SELECTIONCYCLING
Valued Mentor
16 Kudos
Post 8 of 10
Spoiler
Yes, that is the information pane I am seeing.
473 Kudos
Post 9 of 10
04-20-2012 12:37 PM in reply to: KLYPHY
Check out the GRIPMULTIFUNCTIONAL sysvar.
213 Kudos
Post 10 of 10
04-20-2012 01:58 PM in reply to: KLYPHY
RK - He had eliminated SC in an earlier post so that is why I guessed Constraints.
Have a good weekend.
CO
