Upon opening one specific file I receive a message window that will not let me access the file no matter how many times I click Continue or X.
It reads: "Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue. Object reference not set to an instance of object."
The window has a Details drop down menu with a lot of code which reads:
"Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information."
Any help on this issue would be greatly appreciated. Should I attach the file?
Try to run command _RECOVER instead of _OPEN to first check the file's database before it get's loaded.
If that does not help create a new drawing and use command _INSERT to get the content of the 'defect' file inserted and editable.
If the all does not help you can:
- alfred -
