WHEN OUR I CONVERT DWG TO PDF APPLICATION IS CLOSED BY BELOW ISSUE. I HAVE AUTOCAD 2012 OS WINDOWS 7 64BIT
unhandled access violation writing 0x60676550 EXCEPTION AT 60676550H
Solved by braudpat. Go to Solution.
hi, have you tried to install all updates and service packs from autodesk.
or did you try to use other 3rd party pdf converter as shown below. thanks
http://www.bullzip.com/products/pdf/info.php
Hello
Welcome to the Autodesk/AutoCAD Forums !
1) Have you tried to open your DWG in Recover Mode , PURGE , ReSave, ReTest ...
2) If you are on a Network : Have you tried to save on your LOCAL Hard Disk, Quit, Reload, ReTest ...
3) Have you installed the SP 2 for ACAD 2012 ?
Patrice BRAUD
yes i install all updates of autodesk.
no i did not use any third party software
Hello
Q1) Which PDF driver are you using exactly ?
DWG to PDF.pc3 , PDFCreator , Acrobat , etc ??
Q2) Have you the problem with a specific DWG or with all (or almost all) your DWGs ?
Patrice BRAUD
what happens if you plot to DWF instead to PDF, just as a trial if that happens too?
When you write "all drawings" ... do you have tried a new drawing, one line and then plot (new drawing based on an original AutoCAD template)? Same issue then?
- alfred -
