AutoCAD 2010/2011/2012
New Member
gavin
Message 1 of 2 (1,562 Views)
Unable to specify number of turns in helix command
1562 Views, 1 Replies
02-13-2011 05:32 PM
The default number of turns is 3 but I can't specify a different amount. The command prompt automatically adds the default of 3 turns (and CCW rotation for that matter) and skips right on to "specify center point of base". What's going on?
After specifying the top and bottom radius, use the "T" option to set the turns.
*Pro
nestly
Message 2 of 2 (1,556 Views)
Re: Unable to specify number of turns in helix command
02-13-2011 06:34 PM in reply to: gavin
