AutoCAD Forum
Unable to see dimensions on drawing
1 REPLY 1
262 Views, 1 Reply
I am unable to see the dimensions that I measure using power dimensions as per the attachment on the drawings itself. If i want to see it, I have to select the green line, and right click and select the line and select standard as the dimension style. I did not have to previously do all of this.
Appreciate the help!
1 REPLY 1
nestly2
Hi.
The forums are having a small issue with attaching dwg files.  If you need to upload a drawing, try putting it inside a zip file.
Also, if you are using AutoCAD Mechanical, you'll probably recieve the best answers if you post in the AutoCAD Mechanical forum
”Boost
