AutoCAD 2010/2011/2012
Member
bhert07
Message 1 of 5 (224 Views)
Unable to saved file. Losing the original file afterwards
224 Views, 4 Replies
02-12-2013 05:40 PM
Hi all I'm a newbie here in this forum and I need your help.
I found this error a bit strange, my colleague it trying to save a file and this error keeps on coming out (please see attachments). When we try to save it, it only saves as a temp file. When we try to open up the temp file and try to save it, it still doesn't allow us to do. Also, when we cancel the save, the original file will be gone and he will lost all of his data. Does any one of you experience the same problem and got the solution? I would really appreciate your response. Below are the specs of the computer and version of the AutoCAD.
Computer: DELL Precision T5500
OS: Windows 7 Ult
AutoCAD Version: 2011
Also, we're using ProSteel Series 3 as well. We tried saving the file using ProSteel and just AutoCAD but it didn't do the trick. I've tried some options (listed below) that might help it to work but still no luck.
1. Restart the computer.
2. Repair / Reinstall AutoCAD.
3. Give permission to the folder (read from the forum).
Hope someone can help me out.
*Expert Elite*
braudpat
Message 2 of 5 (200 Views)
Re: Unable to saved file. Losing the original file afterwards
02-12-2013 11:07 PM in reply to: bhert07
Hello
1) If you create your own folder locally on your PC
something very short like : C:\DWGTEMP
If you put yours DWGs inside this folder, have you the same problem ?
2) Are you running with a standard Login or with an Admin Login ?
Bye, Patrice
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
Member
bhert07
Message 3 of 5 (197 Views)
02-12-2013 11:25 PM in reply to: braudpat
Hi Patrice,
Yup I've done that one as well. I create a short path for it but still it doesn't work. Also when I'm trying to fix this one, another colleague of my has the same problem but this time his work is save on the network. The user by the way is login as standard one but he as admin privileges only on that computer (not domain admin).
*Expert Elite*
braudpat
Message 4 of 5 (194 Views)
02-12-2013 11:34 PM in reply to: bhert07
Hello
Very strange !
So an other idea : Your anti-virus lets you create files with .DWG type/extension ? I hope so ?
Test : Could you create a text file named "xxxx.DWG" with notepad.exe ???
Bye, Patrice
Member
bhert07
Message 5 of 5 (190 Views)
02-12-2013 11:51 PM in reply to: braudpat
Hi Patrice
Yes, the anti-virus allows us to create .DWG type/extension. Also when I tried the test (creating .DWG file with notepad) it's working and I've create a .DWG file.
Post to the Community
New Post
Need installation help?
