AutoCAD 2010/2011/2012
Product Support
30 Kudos
Post 11 of 13
Re: Unable to break table link in 2012
01-31-2012 08:54 AM in reply to: pfilters
The service pack is the same if it is AutoCAD you are working with:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17692441&linkID=9240618
Make sure you downloaded the 32 or 64 bit version (the one you have) as installing the incorrect version could also trigger the message.
In the About dialog, see if it says AutoCAD only or AutoCAD Mechanical, for example.
Cheers,
Luciane
Active Contributor
3 Kudos
Post 12 of 13
01-31-2012 10:28 AM in reply to: luconceicao
I tried to install both 64 and 32 bit versions of the SP and got the same error for each.  I am using vanilla AutoCad and not Mechanical (i have both), but the folder containing my acad.exe file is named AutoCAD Mechanical 2012.  I downloaded and installed the Mechanical SP and it fixed the problem.
Product Support
30 Kudos
Post 13 of 13
02-01-2012 06:40 AM in reply to: pfilters
Great news, thanks for the update.
Cheers,
Luciane
